Pony, Accent - Kody błędów
e-gen - 25-06-2008, 10:04 Temat postu: Kody błędów PRZYCZYNY ZAPALANIA SIę CHECK ENGINE ( 'MIL' MALFUNCTION INDICATOR LAMP)
• Catalyst
• Fuel system
• Manifold Absolute Pressure (MAP) Sensor
• Intake Air Temperature Sensor
• Engine Coolant Temperature Sensor
• Throttle Position Sensor
• Upstream Oxygen Sensor
• Downstream Oxygen Sensor Heater
• Upstream Oxygen Sensor Heater
• Injector
• Misfire
• Crankshaft Position Sensor
• Camshaft Position Sensor
• Purge Control Solenoid Valve
• Vehicle Speed Sensor
• Idle Control Valve
• Power Supply
• ECM
• MT/AT Encoding
• Acceleration Sensor
• MIL-on Request Signal
• Power Stage
• Heated oxygen sensor (HO2S)
• Manifold absolute pressure sensor (MAP sensor)
• Throttle position sensor (TP Sensor)
• Engine coolant temperature sensor (ECT Sensor)
• Idle speed control actuator (ISC Actuator)
• Injectors
• ECM
KODY BłęDóW (DTC) REJESTROWANE PRZEZ ECM (sterownik, ECU)
Jeżeli na końcu wiersza występuje: O O oznacza to, iż usterka zostanie zapamiętana w ECM oraz zapali cię CE; natomiast jeżeli na końcu wiersza występuje: O X oznacza to, iż usterka zostanie zapamiętana w ECM ale CE się nie zaświeci.
P0030 O2 Sensor Heater - Heater Control Circuit (Bank 1 / Sensor 1) O O
P0031 O2 Sensor Heater Circuit low (Bank 1 / Sensor 1) O O
P0032 O2 Sensor Heater Circuit high (Bank 1 / Sensor 1) O O
P0036 O2 Sensor Heater - Heater Control Circuit (Bank 1 / Sensor 2) O X
P0037 O2 Sensor Heater Circuit low (Bank 1 / Sensor 2) O O
P0038 O2 Sensor Heater Circuit high (Bank 1 / Sensor 2) O O
P0106 MAP Sensor Rationality O O
P0107 MAP Sensor Range Check Low O O
P0108 MAP Sensor Range Check High O O
P0111 Intake Air Temperature Circuit Range / Performance O O
P0112 Intake Air Temperature Circuit Low Input O O
P0113 Intake Air Temperature Circuit High Input O O
P0116 Engine Coolant Temperature Circuit Range / Performance O O
P0117 Engine Coolant Temperature Circuit Low Input O O
P0118 Engine Coolant Temperature Circuit High Input O O
P0121 Throttle / Pedal Position Circuit Range / Performance Problem O X
P0122 Throttle / Pedal Position Circuit Low Input O O
P0123 Throttle / Pedal Position Circuit High Input O O
P0128 Coolant Thermostat (Coolant Temp. below Thermostat Regulating Temp.) O O
P0130 O2 Sensor Circuit (Bank 1 / Sensor 1) O O
P0131 O2 Sensor Circuit Low Input (Bank 1 / Sensor 1) O O
P0132 O2 Sensor Circuit High Input (Bank 1 / Sensor 1) O O
P0133 O2-Sensor Circuit Slow Response (Bank 1 / Sensor 1) O O
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 1) O O
P0136 O2 Sensor Circuit Malfunction (Bank 1 / Sensor 2) O O
P0137 O2 Sensor Circuit Low Input (Bank 1 / Sensor 2) O O
P0138 O2 Sensor Circuit High Input (Bank 1 / Sensor 2) O O
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 2) O O
P0171 Fuel Trim Malfunction - System Too Lean (Bank 1) O O
P0172 Fuel Trim Malfunction - System Too Rich (Bank 1) O O
P0230 Fuel Pump Circuit Malfunction O X
P0261 Cylinder 1 - Injector Circuit Low O O
P0264 Cylinder 2 - Injector Circuit Low O O
P0267 Cylinder 3 - Injector Circuit Low O O
P0270 Cylinder 4 - Injector Circuit Low O O
P0262 Cylinder 1 - Injector Circuit High O O
P0265 Cylinder 2 - Injector Circuit High O O
P0268 Cylinder 3 - Injector Circuit High O O
P0271 Cylinder 4 - Injector Circuit High O O
P0300 Multiple Cylinder Misfire Detected O O
P0301 Cylinder 1 - Misfire detected O O
P0302 Cylinder 2 - Misfire detected O O
P0303 Cylinder 3 - Misfire detected O O
P0304 Cylinder 4 - Misfire detected O O
P0325 Knock Sensor 1 Circuit Malfunction O X
P0335 Crankshaft Position Sensor Circuit Malfunction O O
P0336 Crankshaft Position Sensor Circuit Range/Performance O O
P0340 Camshaft Position Sensor Circuit Malfunction(Bank1 or Single Sensor) O O
P0420 Catalyst System Efficiency below Threshold (Bank 1) O O
P0441 Evap. Emission Ctrl. System Incorrect Purge Flow O O
P0442 Evap. Emission Ctrl. System - Small Leak detected (1.0 mm) O O
P0444 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Open O O
P0445 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Shorted O O
P0461 Fuel Level Sensor Circuit Range/Performance O X
P0462 Fuel Level Sensor Circuit Low Input O X
P0463 Fuel Level Sensor Circuit High Input O X
P0501 Vehicle Speed Sensor Range / Performance O O
P0506 Idle Control System - RPM lower than expected O O
P0507 Idle Control System - RPM higher than expected O O
P0562 System Voltage Low O O
P0563 System Voltage High O O
P0605 Internal Control Module Read Only Memory(ROM) Error O O
P0650 Malfunction Indicator Lamp(MIL) Control Circuit Malfunction O O
P1307 Acceleration Sensor - Rationality O O
P1308 Acceleration Sensor - Signal Check Low O O
P1309 Acceleration Sensor - Signal Check High O O
P1401 DMTL Malfunction O O
P1402 Power Stage (DMTL Motor) O O
P1403 Power Stage (DMTL Valve) O O
P1404 DMTL Heater O O
P1505 Idle Charge Actuator Signal Low of Coil #1 O O
P1506 Idle Charge Actuator Signal High of Coil #1 O O
P1507 Idle Charge Actuator Signal Low of Coil #2 O O
P1508 Idle Charge Actuator Signal High of Coil #2 O O
P1586 MT/AT Encoding Error O O
P1690 Smartra Error (Immobilizer) O X
P1691 Antena Error (Immobilizer) O X
P1693 Transponder Error (Immobilizer) O X
P1694 ECU Siganl Error (Immobilizer) O X
P1695 EEEPROM Error (Immobilizer) O X
Zapamiętane kody błędów można wykasować z ECM odłączając na min. 15 sekund klemę "-" od akumulatora (najlepiej gdyby w czasie tego "manewru" kluczyk ze stacyjki był wyjęty!)
