Galant/Legnum VR4 EC5A/W 97-02 - FAQ: Kody błędów
swinks_UK - 09-03-2012, 16:56
Temat postu: FAQ: Kody błędów
1. ECU (pomarańczowa kontrolka silnika)
11 Oxygen Sensor
12 Air Flow Sensor 13A-11
13 Intake air temperature sensor 13A-11
14 Throttle position sensor 13A-12
15 ISC Motor Position Sensor
21 Engine coolant temperature sensor
22 Crank angle sensor 13A-13
23 Camshaft position sensor (TDC sensor) 13A-14, 13A-15
24 Vehicle speed sensor
25 BARO Sensor 13A-17
31 Knock sensor 13A-18
32 Vacuum sensor
36 Ignition Timing Adjustment Signal
39 Oxygen Sensor
41 Injector system 13A-18
42 Fuel Pump
43 EGR
44 Ignition coil and power transistor unit (Cylinder 1 & 4) 13A-19
52 Ignition coil and power transistor unit (Cylinder 2 & 5) 13A-19
53 Ignition coil and power transistor unit (Cylinder 3 & 6) 13A-19
55 Idle Air Control Valve/Servo Valve Position Sensor
61 Communications wire with A/T-ECU 13A-20
62 Intake air control valve position sensor
64 Alternator FR terminal 13A-21
71 Vacuum control solenoid valve (TCL) 13A-22
72 Ventilation control solenoid valve (TCL) 13A-22
1 A No.1 cylinder misfire detection 13 A – 23
1 B No.2 cylinder misfire detection 13 A – 23
1 C No.3 cylinder misfire detection 13 A – 23
1 D No.4 cylinder misfire detection 13 A – 23
1 E No.5 cylinder misfire detection 13 A – 23
1 F No.6 cylinder misfire detection 13 A – 23
83 AYC fault code
2. ASC/TCL (pomarańczowa kontrolka autka w poslizgu):
11 FR wheel fast sensors (broken wire or short) group
12 FL wheel fast sensor (broken wire or short)
13 RR wheel fast sensor (broken wire or short)
14 RL wheel fast sensors (broken wire or short)
15 wheel fast sensor system (output signal abnormality)
16 The power source voltage abnormality of ECU 13H-4
17 TCL switch circuit systematic 13H- 4
21 FR wheel fast sensor systematic group ]
22 FL wheel fast sensor systematic
23 RR wheel fast sensor systematic
24 RL wheel fast sensor systematic
25 rear wheel fast sensor systems (rear wheel fast sensor left and right simultaneous broken wire) 13H-5
26 rear wheel fast sensor systems (rear wheel fast sensor both breakdown)
27 wheel fast sensor system (front and back wheel fast sensor both breakdown)
31 Ignition switch (IG2) system 13H- 5
32 G sensor circuit systematic group
33 stop lamp switch system (broken wire or ON breakdown)
35 steering wheel sensor (ST-1, 2, N) systematic
36 steering wheel sensor (ST-N) systematic
37 steering wheel sensor (ST-1, 2) systematic
41 FR solenoid valve systematic
42 FL solenoid valve systematic
43 RR solenoid valve systematic
44 RL solenoid valve systematic
45 FR diagonal cutting valve systematic
46 FL diagonal cutting valve systematic
47 FR diagonal raising the pressureValve systematic
48 FL diagonal raising the pressure valve systematic
49 accumulation of pressure valve (FL-FR) systematic
51 valve relay system (ON breakdown)
52 valve relay system (OFF breakdown)
53 motor relay system (OFF breakdown)
54 motor relay system (ON breakdown)
55 motor system (pump motor adherence) the channel 13H- 6
61 Channel of A/T-ECU
63 ECU failing
65 APS or TPS system 13H- 7
66 TPS or APS systematic 13H- 8
67 APS systematic 13H- 8
71 side G sensor circuit systematic group
72 yaw late sensor circuit system (broken wire or short)
73 master cylinder pressure sensor circuit systematic
74 yaw late or side G sensor system Channel 13H- 9
75 Engine ECU system13H- 9
76 Channel of engine ECU
77 TCL vacuum or ventilation solenoid valve systematic 13H- 9
78 accumulator pressure sensor circuit systematic group
81 brake liquid level insufficient
3. AYC (kontrolka ayc):
12 power supply voltage (valve power source) system (broken wire or short) 27− 14
21 FR wheel fast sensor system (broken wire or short) 27− 15
22 FL wheel fast sensor system (broken wire or short) 27− 15
23 RR wheel fast sensor system (broken wire or short) 27− 15
24 RL wheel fast sensor system (broken wire or short) 27− 15#
25 tandem tire 27− 16
26 wheel fast sensor abnormal 27− 17
31 steering sensor (ST−1, ST−2 and ST−N) system (broken wire) 27− 18
32 steering sensor (ST−N) system (short) 27− 19
33 steering sensor (ST−N) systematic 27− 19
34 steering sensor (ST−1 and ST−2) system (short circuit) 27− 20
41 TPS system (broken wire or short circuit) approximately 27− 20
51 G sensor system (broken wire or short circuit) approximately 27− 21
52 G sensor 27− 22
56 side G sensor system (broken wire or short) 27− 21
61 stop lamp switch system (broken wire) 27− 22
65 ABS monitor system (broken wire or ABS breakdown) 27− 23
71 proportional valve system (broken wire or short) 27− 24
72 direction valve (the right) system (broken wire or short) 27− 25
73 direction valve (the left) system (broken wire or short) 27− 26
81 electromotive pump relay system (broken wire or short) 27− 27
82 electromotive pump breakdown 27− 28
83 electromotive pump breakdown 27−30
4. A/T ECU Error codes (migajace N i 3 bieg):
12 Throttle position sensor systematic TCL non equipped car
accelerator pedal position sensor systematic TCL equipped car
Short circuit
13 Throttle position sensor systematic TCL non equipped car
broken wire
14 Throttle position sensor systematic TCL non equipped car
sensor maladjustment
15 oil temperature sensor systematic broken wires 23- 14
21 crank angular sensor systematic broken wire 23- 15
22 input axis speed sensor systematic short circuit/broken wire 23- 15
23 output axis speed sensor systematic short circuit/broken wire 23- 16
26 stop lamp switch systematic short circuit 23- 17
31 LR solenoid valve systematic short circuit/broken wire 23- 17
32 UD solenoid valve systematic short circuit/broken wire 23- 17,
332 ND solenoid valve systematic short circuit/broken wire 23- 17
34 OD solenoid valve systematic short circuit/broken wire 23- 17
35 RED solenoid valve systematic short circuit/broken wire 23- 17
36 DCC solenoid valve systematic short circuit/broken wire 23- 18
41 You do not shift gear do not complete 1st gear 23- 19
42 You do not shift gear do not complete 2nd gear 23- 20
43 You do not shift gear do not complete 3rd gear 23- 21
44 You do not shift gear do not complete 4th gear 23- 22
45 You do not shift gear do not complete 5 speeds 5A/T 23- 23
46 You do not shift gear do not complete retreat (reverse) 23-24
51 Engine ECU Communication abnormal (TCL non equipped car) ASC-ECU (TCL control section) communication abnormal (TCL equipped car) 23-25
52 DCC solenoid valve systematic system defective 23- 18
54 A/T control relay systematic ground short circuits/broken wire 23- 25
56 N range lamp system Ground short circuit 23-26
71 The abnormality of A/T-ECU 23-26
5. ABS (samochody z FWD/AWD):
11 wheel fast sensor (FR) system (broken wire or short) 35B- 5
12 wheel fast sensor (FL) system (broken wire or short) 35B- 5
13 wheel fast sensor (RR) system (broken wire or short) 35B- 5
14 wheel fast sensor (RL) system (broken wire or short) 35B- 5
15 wheel fast sensor system (output signal abnormal) 35B- 6
16 ABS-ECU power source system (voltage abnormal decrease or rise) 35B- 6
21 wheel fast sensor (FR) systematic 35B- 5
22 wheel fast sensor (FL) systematic 35B- 5
23 wheel fast sensor (RR) systematic 35B- 5
24 wheel fast sensor (RL) systematic 35B- 5
27 2WD/4WD detection switch system35B- 7
32 Broken wire of G sensor signal conductor, short circuit or signal abnormality 35C−3
33 stop lamp switch system (broken wire or ON breakdown) 35B-7
41 solenoid valves (FR) systematic
42 solenoid valve (FL) systematic
43 solenoid valve (RR) systematic
44 solenoid valve (RL) system
When there is no response for the drive signal of the solenoid valve which corresponds to each item or ABS-ECU power source systematic breakdown
51 valve relay ON breakdown *
52 valve relay OFF breakdown or ABS-ECU power source systematic breakdown 35B-7- 1
53 motor relay OFF breakdown or ABS-ECU power source systematic breakdown
54 motor relay ON breakdown *
55 motor system (pump motor adherence) or ABS-ECU power source systematic breakdown 35B-7- 1
63 ABS-ECU system *
6. SRS
14 SRS−ECU inside analog G sensor system 52 B - [sehuingu]
15,16 G sensor system for SRS−ECU inside protrusion
17 G sensor system for SRS−ECU inside protruding
21, 22, 61 and 62 driver's seat air bag modules (squib) system 52 B – 8
24, 25, 64 and 65 suicide seat air bag modules (squib) system 52 B – 9
31, 32 SRS−ECU inside DC−DC converter systems 52 B – 10
34 * connector lock system 52B− 10
35 SRS−ECU (air bag development end) system 52 B – 10
41 * IG1 (A) power circuit system 52 B – 10
42 * IG1 (B) power sourceThe circuit systematic 52B− 11
43 SRS warning lamp drive circuit system (The lamp does not light up or The lamp does not go out)
44 SRS warning lamp drive circuit system 52B− 13
45 Non-volatile memory inside SRS−EUC (EEPROM) and the like internal circuit system 52 B – 13
51, 52 Driver's seat air bag module (squib ignition drive circuit) system 52B−13
54 and 55 suicide seat air bag modules (squib ignition drive circuit) system 52 B – 13
71, 72, 75 and 76 right side side air bag modules (squib) system 52B−
73 and 74 right side side air bag modules (squib) ignition drive circuit system 52 B – 14
79 and 93 left side side impact sensor channels 52 B – 14
81, 82, 85 and 86 left side side air bag modules (squib) system 52 B – 14
83 and 84 left side side air bag modules (squib) ignition drive circuit system 52 B – 15
89 and 96 right side side impact sensor channels 52B−15
91* left side side impact sensor power circuit systematic 52B− 16
92 left side side impact sensor system 52 B – 16
94 * right side side impact sensor power circuit systematic 52B− 16
95 right side side impact sensor system 52B−16
