Nasze Mi¶ki - O1T from Romania
best_x_treme - 06-02-2024, 09:13
I've had to replace the old radiator because was leaking from the top. I've also replaced the thermostat and all engine coolant. Plus new stabilizer links for the front with the OE rubber parts.
Bzyk_R1 - 06-02-2024, 18:05
Hi, write to me if you want to sell it.
best_x_treme - 20-06-2024, 15:20
I've managed to change the gaskets from manifold, with some new nuts and washers. The previous gasket was too thin, causesing a little leakeage. Good news is that the manifold is alive, but the heat shield is almost gone, and all its bolts too.
