Regulacja gaźnika w 4G13
Hubeeert
na urlopie
Auto: TOYOTA YARIS 4EVER
Wysłany: 06-04-2006, 15:03   Regulacja gaźnika w 4G13
za stroną http://alflash.narod.ru
To the use some materials of the book "CARBURETORS.T2. Of models from 1970 through 1992"is obtained the permission the management http://.shshsh.autodata.ru - "release and wholesale sale to the special literature on the maintenance and the repair of automobiles ".
ADJUSTMENT, the carburetor it is established on the engine.
1. SEALING.
2. CONTROL OF THE FREQUENCY OF THE ROTATION IDLING.
2. 1. Preparatory conditions.
Before beginning of checking or frequency control the rotations of idling and must be preparatory conditions are satisfied. It is necessary to also observe the following special the preparatory conditions: Temperature the cooling fluid of the engine of 80-90°S.
Headlights and accessory equipment must be it is switched off. On the models for (S) and (N) remove the safety device of daylight lamps (A, fig 1).
Lever of the selector of the automatic transmission place in the position "P".
2. 2. Frequency of the rotation of idling and concentration SO.
Technical specifications (TU):
30/32 DID 800±y00 r/min
30/35 010 (MT.)"shch0±shch0 r/min
30/35 010 (AT) 800±shch0 r/min
32/35010 800±y00 r/min
1,0±0,5%SO
1.8L is not more than 0,5% SO.
Primechaniye: Since carburetor has the locked feedback loop, the adjustment of the quality of fuel mixture usually not it is required. On the models for Sweden (SN) reverse connection can be verified, as it is described below in the division 2. 3. If necessary for the adjustment of the quality fuel mixture during the sorting of the carburetors on the automobiles, supplied other countries, you will be turned to point 2.4. division "the adjustment ".
a) give to engine to work approximately half a minute at the frequency of rotation 3000 r/min, then transfer it to the normal idling.
b) press the pedal of gas one time in order to be convinced of that that the regime of the high frequency of the rotation idling it is switched off.
c) Prover'te the frequency of the rotation of idling. If it does not correspond THAT - adjust spirally idling (A, fig 2).
Note: Checkings and the adjustment one should carry out during 30 seconds afterward the stabilization of the regime of idling, otherwise engine again must work half a minute on the increased revolutions and to be repeated it is stabilized.
2. 3. Checking the feedback at the idling (model SN).
Note: One should carry out the preparatory conditions, indicated in the division the "idle speed adjustment".
a) press one time the pedal of gas and throw out the regime the high frequency of the rotation of idling.
b) you will neglect engine and will establish the regime normal idling.
c) you will disconnect vacuum hose from the second relief valve (fig 4) you will muffle the end hose.
d) you will connect the positive conductor of the voltmeter analog type to the negative conclusion the magnetic valve of feedback (fig 5). You will connect the negative conductor of voltmeter k to mass.
Note: The magnetic valve feedback it must be connected
e) warm thoroughly engine approximately 10 seconds at the frequency of the rotation of 2-etys. r/min.
f) immediately after reduction in the engine revolutions to the single frequency of the rotation of the idling prover'te the behavior of voltmeter. If the pointer voltmeter kolebletsya, and center of oscillation it is located between 2 and 12 volts - system works it is correct.
g) if necessary the regulated frequency the rotation of idling by the adjusting screw (A, fig. 2)
h) if the pointer of voltmeter not kolebletsya or center of oscillation is not within the limits of 2-12 volts, that prover'te the work of all mechanical elements carburetor and the opening of all jets. You will repeat checking.
i) if system does not work afterward remonta/ochistki of the elements of carburetor, you will replace the knot of throttle and you will repeat checking. If system as before not it works, you will replace carburetor.
j) you will connect vacuum hose to the second to controlling relief valve.
2. 4. Adjustment SO (besides models SN).
Prover'te opening v (Fig.2) and, if protective stopping on the spot, you will perform operation a-v. If stopping is absent, that begin from the point g.
a) remove carburetor and stop up it in the vises, in order to the screw of the adjustment of the quality of the fuel mixture was inverted upward (Fig. 3)
b) you will bore the opening with a diameter of 2 mm (A, fig. 3) in housing near the screw of the adjustment of the quality fuel mixture at angle of 45° to the stopping, then you will bore opening to the diameter of 3 mm.
c) put into the opening pintle (D, fig. 3) extract stopping (in, fig. 3) You will establish carburetor on the engine
Note: Take into consideration the preparatory conditions, indicated in the division the "idle speed adjustment".
d) press one time the pedal of gas in order to throw out the regime of the high frequency of the rotation of the unmarried motion.
4), after muffling its end.
f) you will neglect engine and give to it to work on idling not less than 5 minutes. Stabilize the frequency of the rotation of idling.
g) you will connect the positive conductor of the voltmeter analog type to the negative conclusion the magnetic valve of feedback (Fig. 5) You will connect the negative conductor of voltmeter k to mass.
Note: The magnetic valve feedback it must be connected.
h) fix the indication of voltmeter on the the unmarried to motion. You will connect the joint of the sensor of oxygen.
i) give to engine to work approximately 10 seconds to 2-etys. r/min.
j) Prover'te the indication of the voltmeter: if the center beat of pointer it corresponds earlier to the recorded value (±0,shch %) - you pass k the following operation. If the center of the displacement pointers does not coincide with that previously recorded by value, by the rotation of the screw of the adjustment of the quality fuel mixture (in, fig. 2) attain the agreement the center of oscillation of pointer with the value indicated with the frequency of the rotation of idling. Afterward adjustment you will repeat points i) and k).
Note: If necessary the regulated frequency of the rotation of the idling spirally (A, fig. 2)
l) with the engine operating at the idling, open throttle plate, in order to the revolutions they increased to 3000 r/min. Shut the choke shutter. You will be convinced of the fact that during increase in the frequency of the rotation of engine the pointer voltmeter it differs from its position on idling it returns to the the initial position during the restoration of the revolutions of the unmarried motion.
m) you will connect hose to the second air to valve.
n) you will establish new stopping.
3. MECHANISM OF PRIOTKRYVANIYA THROTTLE PLATE.
Checking - 12 vol'tnye models THE ACE or PAS
Note: They must be executed the preparatory conditions, indicated in the division the "idle speed adjustment", and the frequency the rotation of idling it must be correctly it is adjusted.
a) you will neglect engine and will establish the regime idling.
b) you will include head headlights.
c) give to engine to work several seconds with the frequency of rotation 2000 r/min and transfer to the idling.
d) the frequency of the rotation of engine must return k to the value of 8shch0±shch0 r/min.
e) if necessary adjust propeller drive (A, fig. 6) produce retesting.
4. DAMPER OF THROTTLE PLATE.
Technical specifications (TU): y800±200 r/min.
Note. They must be are satisfied the preparatory conditions, indicated in division idle speed adjustment, and the frequency the rotation of idling it must be correctly it is adjusted.
b) turn the lever of throttle plate so, so that the stock of damper would leave to entire length (freed lever A, fig. 7) it touched screw (in, Fig. 7)
c) shut the lever of throttle plate, in order to screw (s, fig. 7) it touched the freed lever.
d) Prover'te the frequency of the rotation of engine into that the moment, when damper begins to work, and you will compare it with TU.
e) if necessary adjust by screw (in, fig. 7)
f) you will let go the freed lever and will be convinced of that that the engine revolutions slowly return to the single frequency of the rotation of idling.
g) on the automobiles, prepared for Sweden, after adjustment you zakontrite screw by paint (in, Fig. 7)
5. Adjustment of the position detector of the choke shutter.
Note: For this operation it is necessary precise digital voltmeter and the special joint MMS №.MD998YA"8.
a) weaken the rope of throttle plate.
b) completely unscrew the screw of the frequency control the rotation of idling (A, fig. 2), counting a quantity of revolutions, and you will be convinced of the fact that throttle plate completely was shut. If this not so, then is the screw of the control of the frequency of the rotation idling (s, fig. 7) it concerns the free lever; therefore turn inside out it completely, counting a quantity of revolutions. Again prover'te, in order to throttle plate was completely closed.
c) the regulator of the high frequency of the rotation idling it is now necessary to let go, lever (A, Fig. 7) it must not concern the fist of that increased the frequency of rotation (in, fig. 7)
d) you will disconnect the joint of position detector throttle plate.
e) you will connect joint Mitsubishi OF №M.D998YA"8 between both by the parts of the joint of position detector (Fig. 10)
f) you will include ignition, without starting an engine.
g) measure the output voltage (on the dark-blue clamp), which must compose 0, 25 v.
h) if stress is differed from that indicated, loosen the screws of fastening position detector throttle plate adjust it by the rotation of sensor (A, fig. 8) Turning on the hour to pointer increases output voltage.
i) you will turn off ignition.
j) tighten screws (A, fig. 2 and s, fig. 7) to the quantity revolutions, calculated earlier.
l) you will disconnect special joint and voltmeter and you will connect the joint of position detector throttle plate.
m) adjust the tension of the rope of the choke shutter, you will neglect engine and prover'te the frequency of the rotation of idling, as it was it is described earlier.
Note: On the models, produced for Sweden, if screws (A, fig. 2 and s, fig. 7) they were they are moved, you zakontrite by their paint.
6. SECOND THROTTLE PLATE.
a) remove the air filter.
b) you will disconnect the vacuum hose of the knot of the diaphragm the drive of throttle plate (A, fig. 11) from carburetor bodies you will connect to it vacuum pump.
c) create vacuum 100 mm RT. st. and completely open the first throttle plate, in order to the second throttle plate completely was opened (for the models for Germany - 25-33% of complete motion).
d) if vacuum is not retained, you will replace the knot the diaphragm of the second shutter. If the vacuum it is retained, but the second throttle plate not it works, prover'te lever actuator throttle plate.
7. CHECKING AUTOMATIC AIR DAMPER.
a) remove air filter and move air damper by hand it must to be moved smoothly and without the gap, in the presence gap you will replace the cover of carburetor in the collection. If it not dvizhetsya, you will clean space all around shutter slightly grease its axis.
b) Prover'te the combination of the adjustment marks housing and the cover of the heater of the air damper (A, fig. 12) If they are not combined, weaken the tie screws turn cover by appropriate by means.
c) at a temperature of the cooling fluid is not above y0°S and the operating at the idling engine prover'te the work of air damper and fist the high frequency of rotation, touching k to the housing of the heater of air damper. Housing heater it must be heated soon afterward engine starting. Air damper must to be opened in proportion to an increase in the temperature automaton. After heating of the cooling fluid it must operate the switch of the high frequency the rotation of idling for the cancellation of this function.
d) if the housing of heater not nagrevayetsya, then prover'te electrical element following by means. You will disconnect the joint of heater and prover'te the integrity of installation and it resistance. Resistance of the thermoelement must comprise approximately 6 Ohm at a temperature 20°S. If this is not so, you will replace the heater air automatic shutter in the collection.
9. HIGH FREQUENCY OF THE ROTATION OF IDLING.
To shch/'90 2700+200 r/min;
From '/'90 of 2'00±200 r/min.
Note: It follows to satisfy the preliminary conditions, indicated it is above for the idle speed adjustment, after by the exception of the removal of air filter.
a) you will disconnect vacuum hose (with the white strip - to '/'88, or with the yellow strip - from "/'88) from the knot the diaphragm of air damper (s, fig. 11)
b) you will install lever (A, fig 8) to the highest the step of the fist of the high frequency of the rotation idling (in, fig. 9)
c) you will neglect engine and prover'te the value the high frequency of the rotation of idling.
d) if the frequency of rotation does not correspond THAT adjust by its screw (D, fig. 7) Rotation of the screw the frequency of rotation clockwise increases.
Note: On the models, produced for Of Sweden, if screw was they will move, you zakontrite it by paint.
e) you will connect vacuum hose to the mechanism priotkryvaniya of air damper you will be convinced of that that the regime of the high frequency of the rotation idling it abolishes.
I consider it possible to add following.
Health is one - diseases (or their reasons appearance) thousand... Therefore, besides that described it is necessary to verify:
- the fuel level in the float chamber;
- the condition of the accelerating pump;
- the state the spark plugs, candle wires and tips, the cover of trembler, "sulky", ignition advance and the vacuum corrector of ignition advance;
- the bimetallic spring of "auto-sucking" and the chain of the supply to it of stress, drives shutting and the opening of air damper, the stepped support of the opening of the choke shutter;
- the drive of the opening of second camera;
- the feed pressure of the fuel of nasosa(0,2...0,25 kg/cm.kV.);
- proper working order (T.e. the absence of the loss airtightness, t.n. the "sucking" of air) the actuating elements of carburetor (vacuum diaphragms) and the vacuum system for the control by the attached equipment of carburetor, trembler;
- the capacity of the emulsion tubes, air and fuel jets;
- the state of pair "needle- saddle" float chamber;
- the absence of the wedging of any the fragment of functional diagram (T.e. thrusts) the drives of actuating elements (in t.h. the drive second camera);
i, t.k. the carburetors of these engines (4G13, 4g-37, G54- b) are equipped with the electronic component of control karbyuratora(.EccU), then it is necessary to verify the state:
- the temperature sensor OZH(.BYA), indication which is used ECU(.A54);
- lambda - zonda(.B"2);
- the pressure sensor of the amplifier of the autopilot upravleniya(.Se2y);
- the potentiometer of the choke of zaslonki(.R'shch); - the "cutoff" 3/m valves of zamedleniya(.Yshch");
- the valve of an increase in the frequency KHKH with the start A/S(.Y8SHCH);
- 3/m valves of an increase in the frequency KHKH(.Y99);
- 3/m administrations of the fuel-air of smes'yu(.Yy2ya);
and control circuit of the described executive by the devices of carburetor.
Naturally, to indicate that enumerated as malfunction on your auto- it would be incorrectly, but as THE POSSIBLE reasons their existence it is not excluded. External repair, alas, the matter is hopeless... Therefore I will allow the council itself: before than to return the executor of the correction auto- into the hands of malfunction, you will estimate its professionalism. As and in medicine - the main thing not to do harm. Detailed the description of the "behavior" of auto- and its analysis with institution, warming up, with the different speed the pedal displacement of gas (T.e. the opening throttle plate), with the sharp acceleration on 2-1 and the 3rd transfers, timely conducting TO, the estimation of the state of fuel and air filters, the "stages" of the development of the situation (gradually or "only yesterday in the evening everything was in order, and today...") and t.d., it allows to reduce field of search...
Part of the attached equipment it is described in separate material
Thomas Jefferson said:
Just think...
Ostatnio zmieniony przez Hubeeert 06-04-2006, 16:03, w całości zmieniany 2 razy
Hubeeert
na urlopie
Wysłany: 07-04-2006, 15:55
Schematy podcisnień w gaźniku:
Just think...
qbartx
Wysłany: 07-09-2006, 09:14
A masz moze Hubeeert, schemat takich podlaczen ale taki na ktorym do aparatu zaplonowego ida 2 weze :?:
Hubeeert
na urlopie
Wysłany: 07-09-2006, 09:28
http://alflash.narod.ru/ - poszperaj może coś znajdziesz.
Ja więcej nie mam.
Just think...
qbartx
Wysłany: 07-09-2006, 14:07
tam szukalem ale nie ma chyba :/
Hubeeert
na urlopie
Wysłany: 07-09-2006, 14:15
To jak znajdziesz nie zapomnij wkleić tutaj.
Just think...
tomusn
Auto: Colt Z34A 6AMT
Wysłany: 07-09-2006, 14:34
ja mam jakieś gaźniki na mailu po angielsku, były one też chyba na http://www.geocities.com/berserko_1/c50/
Tomek
Colt :( Colt :| Colt :)
gabi
Wysłany: 29-01-2007, 12:03
Hubeeert,
Dziękuję za pomoc. Mam jeszcze prośbę, podaj mi co oznaczają skruty na schemacie podciśnień gaźnika.
Serdeczne dzięki. Pozdrawiam.
