Ogłoszenie |
kody błędów |
margac
Auto: Sigma 3000 24V '93
Wysłany: 14-04-2009, 20:57 kody błędów
Witam Koledzy , mam prośbę o podrzucenie linku do listy kodów lub samej listy. Chodzi mi o kody błędów ECS i ECU. Mam padnięty ECS ,zaraz po odpaleniu silnika zapala się dioda alarm i tyle. Pozdrawiam
[ Dodano: 15-04-2009, 08:44 ]
Znalazłem,dzięki. |
VirMan
Mitsumaniak maniacc
Auto: Diamante XS'94
Pomógł: 17 razy Dołączył: 11 Lut 2009 Posty: 1602 Skąd: Tarnów
Wysłany: 15-04-2009, 16:30
Łukasz - masz te kody - wklej jak mozesz :] -wiem wykorzystuje ,ale ty wiesz gdzie to ja wklejam tylko kawałeczek.
FAULT CODE IDENTIFICATION
/ 1g OBD I - ECU FAULT CODES Electronic Control Unit
11 - Oxygen (O2) Sensor. Possible causes: faulty O2 sensor, connector or harness, low or high fuel pressure, defective injector(s), intake air leaks.
12 - Airflow Sensor. Possible causes: faulty airflow sensor, connector or harness.
13 - Intake Air Temperature Sensor. Possible causes: faulty intake air temperature sensor, connector or harness.
14 - Throttle Position Sensor (TPS). Possible causes: faulty TPS, connector or harness, closed throttle position switch.
15 - Idle Speed Control (ISC) motor position Sensor. Possible causes: faulty ISC motor position sensor, faulty throttle position sensor, connector or harness.
21 - Coolant Temperature Sensor. Possible causes: faulty coolant temperature sensor, connector or harness.
22 - Crankshaft Position (CKP) Sensor. Possible causes: faulty distributor assembly (if equipped), faulty CKP sensor, connector or harness.
23 - Camshaft Position (CMP) Sensor. Possible causes: faulty distributor assembly (if equipped), faulty CMP sensor, connector or harness.
24 - Vehicle Speed Sensor (VSS). Possible causes: faulty VSS, connector or harness.
25 - Barometric (BARO) Pressure Sensor. Possible causes: faulty BARO pressure sensor, connector or harness.
31 - Knock Sensor. Possible causes: faulty knock sensor, connector or harness.
32 - MAP Sensor. Possible causes: faulty MAP sensor, connector or harness.
36 - Ignition Timing Adjustment Signal. Possible causes: connector or harness.
39 - Oxygen (O2) Sensor. Possible causes: faulty O2 sensor, faulty O2 sensor heater, connector or harness, low or high fuel pressure, defective injector(s), intake air leaks.
41 - Injector(s). Possible causes: low or high injector coil resistance, connector or harness.
42 - Fuel Pump. Possible causes: faulty ECM, faulty MPI relay, connector or harness.
43 - EGR. Possible causes: faulty EGR valve, faulty EGR temperature sensor, faulty EGR solenoid, faulty EGR vacuum control, connector or harness.
44 - Ignition Coil (cylinders No. 1 and 4). Possible causes: faulty ignition coil, faulty ignition power transistor unit, connector or harness.
52 - Ignition Coil (cylinders No. 2 and 5). Possible causes: faulty ignition coil, faulty ignition power transistor unit, connector or harness.
53 - Ignition Coil (cylinders No. 3 and 6). Possible causes: faulty ignition coil, faulty ignition power transistor unit, connector or harness.
55 - Idle Air Control (IAC) Valve Position Sensor. Possible causes: faulty IAC valve position sensor, faulty IAC motor assembly, faulty ECM, connector or harness.
59 - Rear Oxygen (O2) Sensor. Possible causes: faulty O2 sensor, faulty O2 sensor heater, faulty ECM, connector or harness.
61 - Transaxle Control Module Torque Reduction Signal. Possible causes: faulty transaxle control module, connector or harness.
62 - Variable Induction Control (VIC) Valve Position Sensor. Possible causes: faulty VIC valve position sensor, connector or harness.
71 - Traction Control (TC) Vacuum Valve Solenoid. Possible causes: faulty TC vacuum valve solenoid, connector or harness.
72 - Traction Control (TC) Vent Valve Solenoid. Possible causes: faulty TC vent valve solenoid, connector or harness
FAULT CODE IDENTIFICATION / 1g OBD I - TCU FAULT CODES Transaxle Control Unit
11 - High TPS Output ... No ... Check TPS Operation, Adjustment & Connector, Check Accelerator Switch, Check For Fault Code 24
12 - Low TPS Output ... No ...Check TPS Operation, Adjustment & Connector, Check Accelerator Switch, Check For Fault Code 24
13 - Defective Or Improperly ... No Â? Check TPS Operation & Adjusted TPS Adjustment 14 - Improperly Adjusted TPS ... No ... Check TPS Adjustment
15 ... Open Oil Temperature Â? No ....Check Oil Temperature Sensor Circuit Sensor & Connector (Low Temperature Side)
16 - Shorted Oil Temperature ... No ... Check Oil Temperature Sensor Circuit Sensor & Connector (High Temperature Side)
17 - Oil Temperature Sensor ... No ... Check Oil Temperature Open Circuit Sensor & Connector (High Temperature Side) Or Shorted Circuit (Low Temperature Side)
21 - Open Kickdown Servo ... No ... Check Kickdown Servo Switch Circuit Switch & Connector
22 - Shorted Kickdown Servo ... No ... Check Kickdown Servo Switch Circuit Switch & Connector
23 - Open Ignition Pulse ... No ... Check For Open Circuit Signal Circuit To Pin No. 63 At TCU
24 - Improperly Adjusted ... No ... Check Accelerator Accelerator Switch Switch Adjustment & Or Open Circuit Connector
31 - Open Pulse Generator ... No ... Check Pulse Generator, "A" Circuit Check Vehicle Speed Sensor
32 - Open Pulse Generator ... No ... Check Pulse Generator, "B" Circuit Check Vehicle Speed Sensor
41 - Open Shift Control ... No ... Check Shift Control Solenoid Valve "A" Circuit Solenoid Valve & Connector
42 - Shorted Shift Control ... No ... Check Shift Control Solenoid Valve "A" Circuit Solenoid Valve & Connector
43 - Open Shift Control ... No ... Check Shift Control Solenoid Valve "B" Circuit Solenoid Valve & Connector
44 - Shorted Shift Control ... No ... Check Shift Control Solenoid Valve "B" Circuit Solenoid Valve & Connector
45 - Open Pressure Control ... No ... Check Pressure Control Solenoid Valve Circuit Solenoid Valve & Connector
46 - Shorted Pressure Control ... No ... Check Pressure Control Solenoid Valve Circuit Solenoid Valve & Connector
47 - Open Damper Clutch Control ... No ... Check Damper Clutch Solenoid Valve Circuit Control Solenoid Valve & Connector
48 - Shorted Damper Clutch ... No ... Check Damper Clutch Control Solenoid Valve Control Solenoid Valve & Circuit Connector
49 - Defective Damper Clutch ... No ... Check Damper Clutch Control System Hydraulic Circuit, Check Damper Clutch Control Solenoid Valve, Defective TCU 51 - Incorrect Or No Upshift ... No ... Check Pulse Generators From 1st Gear "A" & "B" Or Connectors, Rear Clutch Slipping
52 - Incorrect Or No Upshift ... No ... Check Pulse Generators From 2nd Gear "A" & "B" Or Connectors, Rear Clutch Slipping, Kickdown Band Slipping
53 - Incorrect Or No Upshift ... No ... Check Pulse Generators From 3rd Gear "A" & "B" Or Connectors, Front Or Rear Clutch Slipping
54 - Incorrect Or No Upshift ... No ... Check Pulse Generators From 4th Gear "A" & "B" Or Connectors, End Clutch Slipping, Kickdown Band Slipping
61 (2) - Shorted Torque ... No ... (3) (4) Check Torque Reduction Request Signal Reduction Request Or Line Or Open Torque Execution Signal Line Converter Reduction Execution Signal Line
62 (2) - Open Circuit On ... No Â? (3) Check Torque Reduction Torque Reduction Request Signal Line Request Signal Line
63 (2) - Shorted Circuit On ... No Â? (4) Check Torque Reduction Torque Reduction Execution Signal Line Execution Signal Line
81 - Open Pulse Generator ... Yes ... See Fault Code No. 31 "A" Circuit 82 - Open Pulse Generator ... Yes ... See Fault Code No. 32 "A" Circuit
83 - Open Or Shorted Shift Â? Yes .. See Fault Code No. 41 & 42 Control Solenoid Valve "A" Circuit
84 - Open Or Shorted Shift ... Yes ... See Fault Code No. 43 & 44 Control Solenoid Valve "B"
85 - Open Or Shorted Pressure Â? Yes ... See Fault Code No. 41 & 42 Control Solenoid Valve
86 - Incorrect Or No Upshift ... Yes ... See Fault Code No. 51, 52, 53 & 54 |
_________________ Inteligence is not everything , wisdom is more than that.
Sigma '93 kombi.
DONE: resurrection
