[3.2 DID] Aktualizacja map MMCS
esawicki
Auto: Outlander 2
Wysłany: 20-05-2009, 20:15   [3.2 DID] Aktualizacja map MMCS
Aktualizacja map Europy
Podaję sposób jak można zaktualizować mapy Europy.
1. Najpierw trzema zdemontować i odblokować dysk twardy .
Tutaj opis jak to zrobić.
http://loapsh.wordpress.c...-removal-guide/
Program pod linuxem do odblokowania dysku jest tutaj:
http://chomikuj.pl/Chomik.aspx?id=esawicki
ANY MODIFICATION ON HARD DISK MAY ALTER MMCS CAPABILITY TO LOAD DATA. DO IT ON YOUR OWN RISK.
The tools needed:
I would try to update my navi using a copy from another disk.
The tools needed to unlock the hard disk are below:
1. One screwdriver
2. One torx size 8 (see img)
3. One IDE adapter from small form to regular IDE (see here and here - both sides) if you use a desktop PC. For laptops, it connects directly.
4. The unlockhd program from iso file (the package is available here or here). You have to write it on CD and boot from it. NO OTHER HDD SHOULD BE ATTACHED EXCEPT THE MMCS' ONE.
5. The unlock key: B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEBAB2DFB19E8996DFAA8C9A8DDFDF - for loader version 261EM (or B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEAAB2DFB19E8996DFAA8C9A8DDFDF for 261UM)
6. One computer with IDE bus.
Procedure
1. To find out what loader version you have:
a) hold SET+NAVI for about 5 seconds to enter "Service Mode" menu
b) press Version Indication
c) note somewhere the Loader version. The key calculation algorithm is presented below. For example, for 261UM version, the key is B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEAAB2DFB19E8996DFAA8C9A8DDFDF (I bolded the difference between 261EM)
2. Flip the screen (push OPEN button in the lower left corner), pull the HDD plastic cover, gently.
3. Unscrew the two screws which holds the hdd. Use the torx. Pull out the hdd.
4. Connect it to IDE bus and power supply.
5. Start the computer, boot from CD, and pick option 3: "Boot linux with locking/unlocking utilities"
6. Wait for root@Xbox-HDM:/1 prompt
7. type unlockhd -p <KEY> (Ex. unlockhd -p B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEAAB2DFB19E8996DFAA8C9A8DDFDF). Double check if necessary
8. The key depends from unit to unit. See below.
9. If the operation is successful, running fdisk -l command will show the partitions (very similar as below). (thanks rcpax)
10. Now you may turn off the computer. The disk is unlocked. You may use it with a Windows computer as a regular disk.
2. Wgrywanie map
Wariant 1 - autka z USA loader wersion UM.
Należy podmienić zawartość partycji z danymi nawigacji (największa, 20 gb) pozostawiając pliki z komendami głosowymi (voice001.me i voice002.me) z wersji oryginalnej (amerykańskiej), w przeciwnym wypadku nie będzie głosu (navi szuka komend 'american english' których nie ma w plikach europejskich). potem zimny restart (klema albo bezpiecznik) i po przeładowaniu systemu na ekranie powinna pokazać się twoja lokacja.
na pozostałych partycjach są kolejno: cały soft (radio, odtwarzacz dvd itp.), baza danych gracenote, zripowana muza i pliki odtwarzacza (playlisty), pusta partycja (?) i partycja bootloadera. podmiana plików na tych partycjach nic nie daje a zamieniając bootloader na wersję europejską można zawiesic system - niestety nie da się w ten prosty sposób z wersji um zrobic em. mmcs jest częściowo sterowane przez canbus i otrzymuje informacje o regionie na który przeznaczony jest samochód z etacs (głownego komputera). sprzętowo obie wersje różnią się tylko dekoderem tmc którego brak w wersji um. podobno instalacja europejskiego mmcs w amerykańskim aucie nic nie daje - urządzenie automatycznie przyjmie amerykańskie ustawienia (czas, częstotliwości radiowe itp.)
Wariant 2 - autka z Europy loader wersion EM.
Wystarczy nadpisać wszystkie pliki partycji z mapami na nowe pliki
zimny restart i gotowe.
3. Tutaj opis jak wgrać wersję loadera „DVD in motion work”.
Wariant 1
Downgraded to this patched NR261EM: http://www.deltainfo.ro/manuals/mitsu/outlander/
direct link: http://www.deltainfo.ro/m.../MMCS-E-DVD.rar
just by replacing the loading.kwi and disconnecting the battery for ~5min.
No changes noticed. only that DVD in motion works
Wariant 2
updating procedure
1. Extract files from archive.
2. Burn the ISO file on a blank, fresh CD (in NERO, Menu -> Recorder -> Burn Image)
3. Start the engine and insert the burned CD into MMCS' unit
4. Wait for it to check the disk and to start the upgrade procedure. It may take up to a minute do make the checks.
5. Wait for the update procedure to finish. This will take 3 to 5 minutes. At the end the unit will reboot.
6. After start, you will be prompted AGAIN to update. Choose NO, the unit is already updated.
7. Remove the CD.
8. Drive carefully while enjoying your DVD movie
WARNING
1. Do not turn off the unit while the program is loading. You may need to go to the MITSUBISHI reseller to restore
the original settings. May cost some cash.
2. From the law's point of view, driving while watching a DVD is 100% illegal. Besides that, it may be a death wish.
If you have it, do not abuse. Your car, your money, your life. And maybe to the others around you. Don't waste them.
Tutaj szczegółowy opis jak zdemontować dysk.
This is a step by step guide on how to extract Mitsubishi Multi Communication System hard disk drive (HDD).
This post is possible only because of valuable contribution of Otaku, rcostin, brian360 and oly_57mpg from mitsubishiforum.com forums. If you find it useful, please do not hestitate to express your gratitude to these great guys.
Also, you should check these two related threads:
http://www.mitsubishiforum.com/m_208034/tm.htm
http://www.mitsubishiforum.com/m_222824/tm.htm
Podaję linki, gdzie znajdziecie wyczerpującą odpowiedź na następujące tematy:
1. Jak odblokować dysk twardy w urządzeniu MMCS.
2. Jak wgrać upgrade oprogramowania umożliwiającego oglądznie DVD w trakcie jazdy.
Inne cenne uwagi dotyczące MMCS.
Oto linki:
http://www.takingthingsap...id=61&Itemid=82
W razie pytań mogę pomóc
Ostatnio zmieniony przez Gene 27-05-2009, 07:45, w całości zmieniany 1 raz
madRenderman
Auto: pajeroIV
Kraj/Country: Russia
Wysłany: 18-06-2011, 11:12
nowe mapy 2011(M190)
http://fileshare.mindbit.ro/alex/
User: mitsu
Pass: 1qaz2wsx
Polluks
Auto: Ford Mondeo MK3; VW Touran
Wysłany: 20-09-2011, 19:06
Czy mapy pasują do MMCSa z outlandera?
esawicki
Auto: Outlander 2
Wysłany: 06-10-2011, 19:09
Pasują wszystko OK
Centurion
Auto: peugeot 4007
Wysłany: 30-12-2011, 17:44
Panowie, ja właśnie szukam kogoś kto zrobił by to w moim aucie. Chodzi o aktualizacje map i wgranie polskiego menu. Posiadam Peugota 4007 ale jak wszyscy wiemy od outlandera różni się znaczkiem na kierownicy.
MartinMM
Auto: Lancer/Pajerko/Gulf
Wysłany: 20-01-2012, 21:03
Płytka w ASO z aktualizacja to koszt 1000 zł ostatnio się orientowałem
WiValdiBB
WiValiBB
Auto: Outlander, Navara, XX
Wysłany: 15-03-2013, 15:44   Mapy M210
Szanownych forumowiczów informuję że są dostępne mapy M210 dla MMCS, wydanie Mitsubishi 2012 a tak naprawdę 07/2011
4x4 ForEver
Bulbo
Auto: Radiowóz Alfa 159
Wysłany: 16-03-2013, 01:02
czy to nie jest aby o 2 lata za późno?
WiValdiBB
WiValiBB
Wysłany: 16-03-2013, 07:12
Bulbo napisał/a:
W przypadku Mitsubishi jest to zupełnie normalne, niestety, chociaż jak dla mnie to również zupełnie nienormalne bo powinni to zatem wgrywać gratis np przy okazji wizyty w serwisie a żądają dodatkowo chora kasę
4x4 ForEver
MartinMM
Wysłany: 18-03-2013, 16:47
jaka cena ?
WiValdiBB
WiValiBB
Wysłany: 19-03-2013, 16:16
MartinMM napisał/a:
jaka cena ?
Barter :)
4x4 ForEver
micpyt
Auto: Pajero IV '07 3,2
Wysłany: 09-10-2013, 09:31
na forum u braci ze wschodu http://faq.out-club.ru/%D...0%BB%D1%8F_MMCS znalazłem plik niby z mapami 2013 (czyli na rok 2012) jedna rzecz mnie zastanawia - łączna wielkość plików to coś około 4,5BG
a łączna wielkość plików na partycji dysku mmcs to około 7,5GB no i jest tylko plik 0.1 a nie ma pliku 0.2 przy czym plik 0.1 jest mniejszy niż na mojej starej mapie na dysku. czy ta mapa to tylko tereny byłego ZSSR ??
WiValdiBB
WiValiBB
Wysłany: 09-10-2013, 12:48
micpyt napisał/a:
Wersja mapy jest w ALLDATA.KWI
I to jest mapa rosyjska ARU_07_201201B
4x4 ForEver
Ostatnio zmieniony przez WiValdiBB 09-10-2013, 16:03, w całości zmieniany 2 razy
micpyt
Wysłany: 09-10-2013, 14:04
przepraszam że zapytam - a co to znaczy ?? czy da się to załadować do mmcs w pajero ??
WiValdiBB
WiValiBB
Wysłany: 09-10-2013, 16:03
micpyt napisał/a:
A po co? Wybierasz się do Rosji?
4x4 ForEver
