Outlander Turbo 2005 Transfer Case Compatibility
ryuzaki
Auto: Outlander Turbo 2005
Kraj/Country: Serbia
Wysłany: 26-12-2022, 19:53   Outlander Turbo 2005 Transfer Case Compatibility
Hello from Serbia everyone :D
I have outlander 2005 2.0 turbo with whiny transfer case. Can someone share me their knowledge and let me know if t-case from other outlander variants (2.0, 2.4. manual or auto) is same as on turbo?
i.e. can I swap t-case from atmo 2.0 to my outlander.
Huge thanks!
W@sio
Well, hello there!
Auto: Doładowane ;-)
Wysłany: 28-12-2022, 09:31
Hi! Just checked the catalog and the case itself looks the same. Just remember that transfer ratio in Turbo is different than in the rest of versions. Maybe someone would check if it fits
ryuzaki
Wysłany: 28-12-2022, 12:58
Thanks for the reply!
I was also doing a little research and yes, the case looks same from outside, it seems to be direct bolt-on.
My concern is that there could be difference in transfer ratio of the case itself. Manual 2.4 and 2.0 have different gearbox from 2.0t as I know.
@W@sio Do you know if transfer case ratios are same?
Bzyk_R1
Outlanderowiec
Auto: O1T LSRG, RX450H
Wysłany: 28-12-2022, 20:47
ryuzaki, transfer Gear ratio is the same in 2.0 and 2.4 and its: 0.3018.
Gdy obowiązek wezwie mnie,
Tam wszędzie, gdzie się pali,
Ty mi, o Panie, siłę daj,
Bym życie ludzkie ocalił.
W@sio
Well, hello there!
Wysłany: 28-12-2022, 22:11
Nope, as Bzyk_R1 said, the ratio is different
ryuzaki
Wysłany: 30-12-2022, 10:16
thanks!
in that case, it seems I will be rebuilding my t-case
Bzyk_R1
Outlanderowiec
Wysłany: 30-12-2022, 12:31
ryuzaki, I have some turbo transfer parts. If you need anything, write me, maybe they will be in better condition.
ryuzaki
Wysłany: 01-01-2023, 10:52
Ok, here is an update on this situation, I have finally took the t-case off, pinion gear is damaged a lot, ring gear is damaged but much less.
Big concern that I have is that my t-case has ring and pinion gears with 53/16 teeth. I think that this is NOT original t-case for outlander turbo, I think that someone before me has put a t-case from regular atmo outlander.
Can someone here to confirm me that t-case for Outlander with ATMO engine has t-case with 53/16 teeth??
Huge thanks guys!
[ Dodano: 09-06-2023, 14:01 ]
here is some visuals :)
