O1T from Romania |
best_x_treme
Forumowicz best_x_treme
Auto: O1T
Dołączył: 22 Kwi 2021 Posty: 64 Skąd: Piatra Neamt / Romania
Wysłany: 06-02-2024, 09:13
I've had to replace the old radiator because was leaking from the top. I've also replaced the thermostat and all engine coolant. Plus new stabilizer links for the front with the OE rubber parts.
Bzyk_R1
Mitsumaniak Outlanderowiec
Auto: O1T LSRG, RX450H
Pomógł: 132 razy Dołączył: 02 Sie 2016 Posty: 5401 Skąd: Pińczów TPI
best_x_treme
Auto: O1T
Wysłany: 20-06-2024, 15:20
I've managed to change the gaskets from manifold, with some new nuts and washers. The previous gasket was too thin, causesing a little leakeage. Good news is that the manifold is alive, but the heat shield is almost gone, and all its bolts too.
