my 89 colt gt turbo will not start |
beaner [Usunięty]
Wysłany: 18-08-2006, 06:35 my 89 colt gt turbo will not start
hi,
just got this 89 colt gt turbo recently.
it only has 100k miles on it.
at first there was no spark,
so i change the cam angle sensor, the ecu, and the ignitor chip and
now it gets spark.
also it gets fuel, i smell it on the plugs and in the tailpipe
i also put in newer spark plugs, and they spark also.
when the car tries to start, the cranking is very healthy.
for a few days it would just turn over, yesterday it sputtered for a few seconds but nowhere near a start.
can anyone help me figure this out? i am lost on what to do, unless the wiring harness has problems or there are electrical gremlins.
the person who i bought it from, said it ran for a few weeks but then stopped.
also the compression is almost perfect in every cylinder
thanks
pmmcky beaner |
Carl Morris [Usunięty]
Wysłany: 18-08-2006, 06:51
That's an unusual one, it sounds like you've successfully verified spark and fuel and that the timing belt isn't broken . Have you verified the firing order, that the spark plugs are connected correctly? I realize that doesn't go with the idea that it used to run OK and nothing has changed since then.
Do you have access to a datalogger? If you have a laptop with a DB9 serial connector it's not too difficult to make the cable and "borrow" the software. It would be interesting to know if your mass air meter signals all look reasonable.
If you really do have spark that's timed in the general vicinity of correct, it implies that you either have way too much or way too little fuel. Do you have a way of checking fuel pressure? There's always the chance the filter is clogged or the pump has died. |
beaner [Usunięty]
Wysłany: 18-08-2006, 07:38
| Carl Morris napisał/a: | That's an unusual one, it sounds like you've successfully verified spark and fuel and that the timing belt isn't broken . Have you verified the firing order, that the spark plugs are connected correctly? I realize that doesn't go with the idea that it used to run OK and nothing has changed since then.
thanks for your quick post
i have the plugs connected good, i checked the firing order and it is also good according to my information (can u tell me again the order, maybe i did it wrong)
i have a friend with a datalogger, i will try to have him come over.
also the timing belt is fine, it is exposed for now lol.
your fuel information is interesting
the last owner dropped the gas tank (Stupid) because he thought the pump was bad. it is not. i had to reassemble everything quickly and perhaps there is a pressure leak. a clogged filter might be it. but the engine seems to get gas when i remove one plug.
is there a scrader valve on the fuel rail to check pressure? i do have a gauge.
thanks |
Dołączył: 28 Kwi 2005 Posty: 24705 Skąd: był Malbork, teraz Gdańsk
Wysłany: 18-08-2006, 08:14
my advice is to check fuel pressure close to injector pipe (after fuel filter)
it should be from 250 kPa (closed loop) to 350 kPa (open loop), where closed and opened means, that vacuum hose (black with blue stripes) is connected or not to the fuel pressure regulator (at the end of intector pipe)
as an example i can say, that my friend got something like you - someday his car stopped and didn't work;
there was a problem with ECU (capacitors), and after change this caps spark back; i smell the fuel (after removing spark plug), but (after 3 months) it shows, that the fuel pump was bad - his mechanic change the fuel pump, but not brand new - it was regenered, and the pressure was too low to start
after change fuel pump to brand new car started and is 'on-line' to now
firing order is 1-3-4-2, where 1 cyl. is on timing belt side - you should check, that the spark is on all sparkplugs
when there are: spark and fuel, and they're in suitable time, the explosion engine MUST work; to synchronize it is used a crankshaft position sensor
if you replaced ecu, cam- and crank-shaft sensor, coil and fuel pump it should be working |
Wysłany: 18-08-2006, 23:37
| beaner napisał/a: |
There was not a schrader valve on my Galant. Long ago I used a special "banjo" bolt with a hole in it at the fuel filter outlet, instead of the original one. That allowed me to detect pressure with a mechanical gauge. Now I use aftermarket AN lines and connectors and filter, and have an electronic gauge sender at that point. It is possible for the ignition to fail in a way that two of the plugs no longer get spark, and two function normally. The ECU capacitors are always a possibility, but since you said that you had swapped ECUs, I assumed that possibility had been ruled out. |
Hubeeert
Mitsumaniak na urlopie
Auto: TOYOTA YARIS 4EVER
Wysłany: 19-08-2006, 00:10
All posibilities are described in service manual.
If you have checked everything I would check the ECU once more because when this small things blow they usually damage the small lines on the surface. Or you just forgot to weld the "legs" on both sides. There is no black magic in it - if everything else is OK then it has to be ECU or blown motor. |
Thomas Jefferson said:
Just think...
beaner [Usunięty]
Wysłany: 19-08-2006, 00:40
| Hubeeert napisał/a: | All posibilities are described in service manual.
i have 4 spare ecu's that i have been trying. some are 1g, 2g dsm ecus but they are very similiar. also cant be blown motor since all compression is perfect? |
Hubeeert
Wysłany: 19-08-2006, 00:46
As far as I remember there are some differences between Mirage Turbo ECU and 1G one.
I am not sure if they are just bolt on. |
Just think...
beaner [Usunięty]
Wysłany: 19-08-2006, 02:52
| Hubeeert napisał/a: | As far as I remember there are some differences between Mirage Turbo ECU and 1G one.
all the ECUs clip into the harness the same.
tonight the cranking was better , like it almost wanted to start.
but still no start. made sure there was plenty of gas also.
also i changed the coolant temp sensor to one that i know works, still nothing.
anyone know anything else? seems i tried everything |
shovel [Usunięty]
Wysłany: 19-08-2006, 04:03
i wish you good luck. i had some similar problems with my last galant. there was a spark, there was a fuel, but motor won't start. it was always almost and sometimes there was a shot into a intake. timing belt was good, ECU didn't report any errors. I gave up on it, i sold engine to some guy in Cracow and he is very happy about way engine works. It was some sort of problem with electronics, but i didn't have a time/enough good will to check every sensor. write about what was a reason of failure.
good luck. |
Wysłany: 19-08-2006, 07:20
| beaner napisał/a: |
If you've verified fuel pressure then I'd recommend trying to find a CSM ECU just to try it. One problem is that I think the Colt ECU used 390cc injectors and the DSM ECU is designed for 450s. I'd expect it to start anyway, even at 13% lean. But I don't know if the mass air meters are the same. You may be just a bit too lean to start with a DSM ECU if there is more than one factor creating a lean condition. |
Hubeeert
Wysłany: 19-08-2006, 10:25
| beaner napisał/a: | | ECUs clip into the harness the same |
Yes they are, indeed. But the wires are not the same. As I said I remember a difference between them. Check at www.4g61t.org .
I'm not sure if that's the problem. I'm not but it may be the reason. |
Just think...
beaner [Usunięty]
Wysłany: 05-09-2006, 02:56
hi,
it is possible that the injectors in the engine are in correct from the old older. they are pink top hat injectors. does anyone know what CC the pink injectors are?
thanks |
Wysłany: 05-09-2006, 18:00
| I thought they were the stock 390s. |
