Tajemnicze gniazdo pod recznym |
supeer
Auto: C-crosser 2.2 2010r
Pomógł: 4 razy Dołączył: 03 Sty 2015 Posty: 217 Skąd: Elbląg
Wysłany: 11-06-2016, 14:49 Tajemnicze gniazdo pod recznym
Interesuje mnie do czego sluzy nie podlaczone gniazdo w tunelu pod hamulcem recznym, ktos moze wie?
(zawiera 3 piny)
Pomógł: 828 razy Dołączył: 01 Sty 2010 Posty: 21231 Skąd: Częstochowa
Wysłany: 11-06-2016, 17:32
Tutaj masz schemat wszystkich kostek Outka 2012 .
http://mmc-autoelectric.o...0164AB00ENG.pdf
http://mmc-autoelectric.o...0164AC00ENG.pdf
A tutaj ich opis.
| Cytat: | C-01 (24) J/C (CAN3)
C-02 (4) Meter information switch
C-03 (24) Combination meter
C-04 (24) J/C (CAN2)
C-05 (5) Photo sensor <Vehicles without rain sensitive AUTO wiper>
C-06 (12-GR) Multivision display <Vehicles with MMCS>
C-07 (7-G) Multivision display <Vehicles with MMCS>
C-08 (32-GR) Multivision display <Vehicles with MMCS>
C-09 (3-GR) Multivision display <Vehicles with MMCS>
C-10 (5-GR) Multivision display <Vehicles with MMCS>
C-11 (17-GR) Multivision display <Vehicles with MMCS>
C-12 (4-Y) Passenger’s (Front) air bag module (squib)
C-13 (4) Passenger’s air bag cut off switch
C-14 (2-B) Glove box lamp
C-15 (10-G) CAN box unit <Vehicles with MMCS>
C-16 (18) Radio and CD player or spare connector (for audio) <Vehicles without MMCS>
C-17 (18) Instrument panel wiring harness and audio navigation display wiring harness combination <Vehicles with MMCS>
C-18 (20) Radio and CD player or spare connector (for audio) <Vehicles without MMCS>
C-19 (20) Instrument panel wiring harness and audio navigation display wiring harness combination <Vehicles with MMCS>
C-20 (24) Spare connector <Vehicles without MMCS>
C-21 (24) Instrument panel wiring harness and audio navigation display wiring harness combination <Vehicles with MMCS>
C-22 (24) Instrument panel wiring harness and floor wiring harness combination
C-23 (4) Front wiring harness and floor wiring harness combination
C-24 (20) Instrument panel wiring harness and floor wiring harness combination
C-25 (5) Drive mode selector <4WD>
C-26 (10) Shift switch assembly <A/T, CVT> or shift lever <TC-SST>
C-27 (2) Accessory socket (Front floor console)
C-28 (2) PTC heater <4N1>
C-29 (3) PTC heater <4N1>
C-30 (4-B) G and yaw rate sensor <Vehicles with ASC>
C-31 (32-Y) SRS-ECU
C-32 (24-Y) SRS-ECU
C-33 (12) Wireless control module <Vehicles without KOS>
C-34 (12) Receiver antenna module <Vehicles with KOS>
C-35 (24) Instrument panel wiring harness and floor wiring harness combination
C-36 (20) Instrument panel wiring harness and floor wiring harness combination
C-37 (22) Instrument panel wiring harness and front wiring harness combination
C-38 (16-BR) Instrument panel wiring harness and front wiring harness combination
C-39 (2) Instrument panel wiring harness and front wiring harness combination
C-40 (12) Instrument panel wiring harness and roof wiring harness combination
C-41 (2) Clutch switch <M/T>
C-42 (8) LIN cut off control unit <Security alarm system>
C-43 (12) No connection <6B31>
C-45 (32) AS&G-ECU
C-46 (10-GR) DC/DC converter <Vehicles with AS&G>
C-47 (6) Instrument panel wiring harness and front wiring harness combination <Vehicles with AS&G>
C-48 (2) Clutch interlock switch <Vehicles with AS&G>
C-51 (2) Cigarette lighter
C-52 (24) Spare connector
C-101 (6-GR) Headlamp levelling switch <Headlamp manual levelling system>
C-102 (6) ASC off switch
C-103 (6-L) Sonar switch <Reversing sensor system>
C-104 (40) KOS-ECU
C-105 (24) J/C (CAN 1)
C-106 (16) Centre panel unit
C-107 (2) Radio antenna
C-108 (5-G) Outside/inside air selection damper control motor
C-109 (5-G) Mode selection damper control motor
C-110 (16-B) A/C-ECU
C-111 (20-B) A/C-ECU
C-112 (26) Headlamp automatic levelling-ECU
C-113 (12) Instrument panel wiring harness and front door wiring harness (Passenger’s side) combination
C-114 (24-BR) Instrument panel wiring harness and front door wiring harness (Passenger’s side) combination
C-115 (2) Blower motor
C-116 (5-G) Air mixing damper control motor
C-117 (2) Accessory socket (Rear floor console)
C-118 (6-B) Audio and video adapter
C-119 (2) Fin thermo sensor
C-120 (12) A/C control panel
C-121 (4) Power transistor
C-123 (2) Interior temperature sensor
C-124 (6-B) Accelerator pedal position sensor
C-125 (24-B) Corner sensor/back sensor-ECU <Reversing sensor system>
C-126 (4-B) Stop lamp switch
C-127 (16-B) Diagnosis connector
C-128 (12) Instrument panel wiring harness and front door wiring harness (Driver’s side) combination
C-129 (24-BR) Instrument panel wiring harness and front door wiring harness (Driver’s side) combination
C-130 (16) 4WD-ECU
C-131 (22) Front wiring harness and floor wiring harness combination
C-132 (10-B) Fuel additive-ECU <4HK>
C-133 (2-B) Exhaust gas temperature sensor <4HK>
C-134 (4-B) Oxygen sensor (Front) <4B1>
C-135 (22) CVT-ECU <4B1>
C-136 (26) CVT-ECU <4B1>
C-137 (22) A/T-ECU <6B31>
C-138 (26) A/T-ECU <6B31>
C-140 (6-B) Audio adapter
C-141 (16) Shift lever <TC-SST>
C-143 (8) Stop lamp relay
C-144 (28) USB box
C-146 (16-BR) Floor wiring harness and 4WD-ECU sub wiring harness combination
C-147 (28) Hands free-ECU
C-148 (6) ASC/AS&G off switch |
supeer
Wysłany: 12-06-2016, 13:04
Wychodzi na to, ze to zlacze wykorzystywane jest w wersji z automatem...takze problem rozwiazany.
Dziekuje za diagarm |
