Przesunięty przez: Bzyk_R1 15-08-2022, 20:44 |
How to install an EVO MOMO steering wheel in Outlander 1 |
best_x_treme
Forumowicz best_x_treme
Auto: O1T
Dołączył: 22 Kwi 2021 Posty: 63 Skąd: Piatra Neamt / Romania
Wysłany: 31-07-2022, 12:08 How to install an EVO MOMO steering wheel in Outlander 1
I remember, before buying my O1T, that I’ve seen pics with MOMO steering wheel in O1T. I was impressed with the look and keep that in mind for future plans with my car. Then I’ve read here on other topics that to install MOMO you have to cut your steering wheel support and weld it to MOMO, as to fit the O1T steering column. This approach is complicated, so I’ve decided not to go this route and give up this cool steering wheel. But later I’ve found new information, that you can swap your column with an early 2003 pre-facelift Outlander and happily install MOMO. This look like something I could do. So, I’ve bought the steering wheel and a steering column from a 2003 Outlander (not turbo) and went to install them. I’ve managed to install the new column, but unfortunately this will not fit perfectly, basically there is no space to tilt up and down. So, I knew at this point that the only way to install it would be to swap the inner shafts of the 2 columns, to keep my column but with the pre-facelift shaft.
Some used a shaft from Lancer, but this will be slightly shorter. The shaft from Outlander pre-facelift is perfect in lenght. In this pics from left to right, Outlander prefacelift column, Outlander facelift column and a inner shaft from Lancer.
you can see in this photo how the whole column from pre-facelift is different
If you install this in a Lancer, you can use the whole column, as is identical between pre-facelift and facelift.
I will describe more detailed how to deal with the inner shaft, the other steps are relatively easily to follow.
- disconnect battery
- remove airbag and steering wheel
- disconnect the panels under steering wheel
- remove airbag SRS clock spring and headlight switch and wipers. Make sure you don’t rotate the airbag clock spring!
- remove the 4 bolts that keep the steering column and remove the column by pinch the steering column shaft clip with pliers and pull up. This is from the manual, seems important : The tilt lever should be held in the lock position until the steering column shaft is installed to the vehicle. If the steering column is removed with the tilt lever released, or the tilt lever is released after the steering column shaft was removed from the vehicle, the steering column cannot be reinstalled correctly. If the steering column is installed incorrectly, the collision energy absorbing mechanism may be damaged.
- I have removed the ignition lock too, mainly because initially I want to use the whole column, but I think you can skip this part. There are 2 bolts here, I did a cut with a Dremel tool and unscrew them easily.
- The most important part of this post is to describe how to swap the shaft, I’ve search online and I didn’t find much, so here’s how I did it. To do this you will need a bearing puller set, I’ve used Yato YT-06412. To remove the shaft with the puller is quite simple just connect the puller as in photo. Make sure you unlock the ignition, by turning the key. Do not forget to remove the c clip that secures the shaft, first!
- Now that you have the shaft removed, is a good time to apply new grease to bearings.
- To install the shaft back in, was the real challenge. I’ve tried different strategies like hammering, but this is hard to do because the bearing from top is quite narrow and the shaft needs a lot of force to go in. I’ve bought a long screw (M5x80mm) that I’ve put inside the column, then I’ve connected the puller as in photo and secure the screw at the end with some washers and a nut. Now in order to pull the shaft up, slowly undo the 2 bolts of the puller. Undo the bolts only halfway, screw all back in and repeat this until you pull up the shaft completely and you can reinstall the c clip. This works perfectly and you don’t have to worry about damage something. Make sure you buy some additional screws and nuts, as these may fail and need replace to finish the job.
- Reinstall all back, the biggest issue is to put the column back, you have to pinch the steering column shaft clip with pliers and put it back in the lower shaft, I strongly advise that you have somebody to help you with the column or, if you work alone, you could use something like in this photo. To pinch the column clip, I’ve found this type of plier works best, Yato YT-2476 in photo.
- and finally you'll have to make a small adaptation for the horn to work, as the connectors are different:
Good luck with your install, the final result definitely worth the effort:
before:
after:
DAMON
Auto: OT1
Wysłany: 04-08-2022, 08:43
Very good job and documentation, looks great |
best_x_treme
Auto: O1T
Wysłany: 04-08-2022, 09:31
Thanks, hope it will be helpful. Feel free to add your thoughts or complete what I've missed
| DAMON napisał/a: | Very good job and documentation, looks great |
ciuciekk
Auto: Outlander Turbo
Wysłany: 15-08-2022, 20:20 Kierownica Outlander
Witam wszystkich.
Nie znalazłem podobnego tematu więc zakładam nowy.
Czy do Outlandera 1 gen pasuje jakaś kierownica P&P? np. z Colta lub innych.
Bo z kierownicą Evo jest trochę zabawy ,a ori troszkę odstrasza. |
Bzyk_R1
Mitsumaniak Outlanderowiec
Auto: O1T LSRG
Pomógł: 132 razy Dołączył: 02 Sie 2016 Posty: 5387 Skąd: Pińczów TPI
tościk
Auto: '20 Yukio 1.2T
Pomógł: 9 razy Dołączył: 06 Gru 2017 Posty: 634 Skąd: z nienacka
Wysłany: 16-08-2022, 13:11
| ciuciekk napisał/a: | Nie znalazłem podobnego tematu więc zakładam nowy.
Czy do Outlandera 1 gen pasuje jakaś kierownica P&P? np. z Colta lub innych. |
| Cytat: | | Nie znalazłeś piszesz, hmm... |
Bzyk_R1, no tak prawdę mówiąc, to tak jak kolega ciuciekk napisał, jeśli chodzi o momo, to P&P to nie jest |
Bzyk_R1
Auto: O1T LSRG
Wysłany: 16-08-2022, 20:31
tościk, Tobie nie trzeba chyba powtarzać że nic w tym aucie nie modzi się P&P. Autor posta szukał podobnego tematu dotyczącego zmiany kierownicy no to mu pomogłem znaleźć.
Kierownice które jeszcze mogą pasować to te od Lancera VII (nie momo) oraz ta od Colta. Nie montowałem jednak takich i nie wiem ile z tym zabawy, wiem że parę Outlanderów z taką kierą jeździ. |
Tam wszędzie, gdzie się pali,
Ty mi, o Panie, siłę daj,
Bym życie ludzkie ocalił.
STOP HYBRID GO LPG |
best_x_treme
Auto: O1T
Wysłany: 17-08-2022, 09:16
| Changing the inner shaft is P&P, so I think it is correct to say that changing to MOMO is P&P. For all this, you just need an inner shaft and a MOMO, that's it, no cutting or anything. |
